GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
07-24-2008, 21:53 | #2 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Voodoo L:ounge
Member: 15565 Status: Offline Thanks Meter: 3 | @Modeltime Tomtom works great on 6220, but only with an external Bluetooth GPS. If you try it using the internal GPS it doesn't work, the N95 copy of TT uses a BT.sisx file which hangs on the 6220, if there was a way of running bt.sisx on the 6220, then it would work with the 6220's internal GPS. But for now, its external only. |
08-26-2008, 02:56 | #6 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
WBR, DebeliaMark, BG | |
08-26-2008, 05:11 | #7 (permalink) | |
Junior Member Join Date: Aug 2008
Member: 838114 Status: Offline Thanks Meter: 7 | Quote:
Garmin Mobile XT (Symbian S60 v4.10.60) --------------------------------------- http://www.megaupload.com/?d=6GK68Y56 Garmin Mobile XT (Symbian S60 v4.20.20) for N78 -------------------------------------------------------- These Files Update the Garmin Xt 4.10.60 to 4.20.20 for the Symbian S60 Based Device's All you need to do is extract all files and copy them all to the Garmin Folder then run the http://www.mediafire.com/?sharekey=1...db6fb9a8902bda GarminMobileXT.sis from the Garmin Folder to update Garmin Mobile XT Support Files v4 --------------------------------- This pack contains all the Voice files for the Garmin XT http://rapidshare.com/files/75126810...es_v4.***x.rar http://rapidshare.com/files/83242741...es_v4.***x.rar http://www.megaupload.com/?d=ZAUWI4Q9 Garmin KeyGen and IMEI Calculator --------------------------------- This contains the Garmin XT Keygen for for Card ID and the IMEI Calculator to convert Phone IMEI to Unit / Card ID http://rapidshare.com/files/85724087...Calculator.rar http://www.megaupload.com/?d=QJHET1VZ | |
The Following 3 Users Say Thank You to teckyuen For This Useful Post: |
09-02-2008, 09:30 | #9 (permalink) | |
Here is the file i upload, download it and use notepad to change the code. http://www.mediafire.com/?y5zaaudmao0 After start your garmin and you can select internal GPS. Map you need goto find . You never mention what map you need You can find map in this forum | |
09-04-2008, 09:49 | #10 (permalink) |
Member: 850016 Status: Offline Thanks Meter: 1 | thanks alot, once i download the file i know wat is wrong as my comp was set to hide the known file extention so didnt delete away the .txt. rgding the maps...i did download 1 from malsing, which they say dont need any code to unlock, but after i install i still cant view the maps.....not sure wat wrong. is it becos i didnt get a fix on the sat signal? is it becos i still need to place a empty GMAPSUPP.UNL b4 it cant be use? or is it becos of something i havent do. btw i can use the internal gps already, very much thanks to u teckyuen. |
09-04-2008, 09:50 | #11 (permalink) |
Member: 850016 Status: Offline Thanks Meter: 1 | thanks alot, once i download the file i know wat is wrong as my comp was set to hide the known file extention so didnt delete away the .txt. rgding the maps...i did download 1 from malsing (singapore and malaysia map), which they say dont need any code to unlock, but after i install i still cant view the maps.....not sure wat wrong. is it becos i didnt get a fix on the sat signal? is it becos i still need to place a empty GMAPSUPP.UNL b4 it cant be use? or is it becos of something i havent do. btw i can use the internal gps already, very much thanks to u teckyuen. |
The Following User Says Thank You to Mitsuokae For This Useful Post: |
09-05-2008, 05:41 | #12 (permalink) | |
Which Software GPS work on Nokia n73 | milkovic | GPS devices , Navigators & Maps | 1 | 09-01-2008 11:12 |
which garmin software will work with my phone?? | dragomddragom | GPS devices , Navigators & Maps | 1 | 08-27-2008 08:46 |
Which box will work with original phoenix? | Crazy_ratata | Nokia Base Band 5 ( BB-5 ) | 3 | 03-30-2008 19:54 |
c2200 i needs WHICH cable to work with vygistoolbox?? | SicilianBoy | VygisToolbox | 8 | 12-11-2005 13:24 |
Which firmware versions work with T10s 99W52 ? | taichip | Old Ericsson Phones & Sony Phones | 0 | 02-18-2001 04:28 |
