Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
06-14-2008, 19:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Sign symbian apps step by step 100% Tested Please Note these points before proceeding so you know that what you are doing and what your target is: Your aim is to Install, any Mobile Application (incl. N-Gage Games on supported handsets only) on your Nokia Series 60v3 Device, and here is ONE TIME solution to install all softwares/games on your devices. Follow these detailed guided steps to run applications on your S60v3 devices: Step1:- Install the TRK application on your phone! Step 1.2) There are two versions of TRK application, known as Pre-FP1 for which the filename is "s60_3_0_app_trk_2_8_6.sis" which can be found in the application folder inside "Secman_Binpda" folder. Other version is for FP1 devices, for which TRK file you need to install is "s60_3_1_app_trk_2_8_6.sis". Step 1.4) Here is the list of devices, so you may choose to install the appropriate version: Pre-FP1 devices: (s60_3_0_app_trk_2_8_6.sis) ------------------- Nokia N77 Nokia E61i Nokia E65 Nokia N93i Nokia N91 8GB Nokia E62 Nokia E50 Nokia 5500 Nokia N93 Nokia N73 Nokia N80 Nokia N71 Nokia N92 Nokia E70 Nokia E60 Nokia E61 Nokia 3250 FP1 devices: (s60_3_1_app_trk_2_8_6.sis) --------------- Nokia 6124 classic Nokia N82 Nokia N95-3 NAM Nokia E51 Nokia N95 8GB Nokia N81 Nokia N81 8GB Nokia 6121 classic Nokia 6120 classic Nokia 5700 XpressMusic Nokia 6110 Navigator Nokia E90 Communicator Nokia N76 Nokia 6290 Nokia N95 Nokia N96 Nokia N78 Step 1.6) Now TRK application should be on your phone after installed on your phone, When you will open the application, it may give show you message like: "Status: Not Connected Failed to open port. Error Code: -21" This is because, we have not yet configured the application to connect via USB cable (we will not use Bluetooth as method). Now select options and then settings, it will look like this: Select the following options, like in this picture: Then goto options again, and select Connect: It should now look like this: Keep Metro TRK Running in background. Exit via the Menu Key. Step2:- Installing SecMan.exe on your PC Step 2.1: Make sure to Connect your mobile to your PC via USB cable, befre proceeding to next step. Step 2.2: Now, go back to your PC and open the folder where all the files of SECMAN are extracted. Run Secman.exe. Click Next. On the Next Screen, just check the option "Find MetroTRK Port Automatically" and click Next. Something like this. (Pic Included) (Make sure that TRK application is still running on your mobile, otherwise it will not install.) After some time, it will start installing the SecMan application to your phone. You will get something like this: After install, you should have Secman on your mobile phone. Step3:- Secman Settings Now Secman should be on your phone. Open SecMan,go to Options and select "Turn Plat Security OFF". Important: You will need to turn "Turn Plat Security ON" if you before installing any N-Gage game, else it will not work. Then, go to Options again and select "Install ROOT Certificate". Now you can install, any games, softwares released by BINPDA. Step4:- Sign Un-Signed Apllications Put any Unsigned File in the same folder which where RootSiGN.exe found. I have selected LandScape Pro application. Open ROOTSiGN.EXE from the same folder, select the SIS File and click "Root Sign the file". Important: If error than just rename file to short file name and try again. After its done, you will have 2 files in the folder. One Unsigned and One RootSigned. Install the Rootsigned file and enjoy. Important: After you have installed the files, go to SecMan and go to Options > Turn Plat. Securities ON. Its not a good idea to keep platform securities off always. They are there for a reason. Like, to install N-gage Games you will need to turn, Turn Plat. Securities ON else it may create issues. Now you can install Unsigned BiNPDA files, or another kind of apps for s60v3 devices, and your Phone will not ask for Certificate errors and Untrusted Supplier issues and blah blah. Download crack: Enjoy signed apps No Certificates no symbiansigned... anymore!! any problem feel free to contact. Don't forgot to use thanks buttons. This guide is courtesy of www.funmaza.com Kind regards, Vicky |
The Following 44 Users Say Thank You to wsw243 For This Useful Post: |
06-15-2008, 11:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Somewhere there Age: 14
Member: 567723 Status: Offline Thanks Meter: 314 | It's work very fine on my Nokia 5500 Sport ,good work bro br >>> GsmFreeShop <<< |
The Following User Says Thank You to GsmFreeShop For This Useful Post: |
06-16-2008, 05:27 | #4 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | here is mirror http://rapidshare.com/files/12267647...tool_.rar.html http://www.2shared.com/file/3444066/...racktool_.html Kind regards, Vicky |
The Following 2 Users Say Thank You to wsw243 For This Useful Post: |
06-16-2008, 17:21 | #5 (permalink) |
Junior Member Join Date: Jul 2006
Member: 304359 Status: Offline Thanks Meter: 1 | Worked fine on my laptop and also on my office pc but not on my collegues pc. The only difference we could find was that he had just updated PC Suite to the latest version. Any one else experienced a problem after updating ? Other than that excellent system - Many thanks |
06-16-2008, 17:59 | #6 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | to all If you like this than use Thanks button and Rate this thread instead of post thanks, good work etc to save forum space. hope all understand. Kind regards, Vicky |
The Following 3 Users Say Thank You to wsw243 For This Useful Post: |
06-23-2008, 11:04 | #10 (permalink) | |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Quote:
Kind regards, Vicky | |
06-30-2008, 10:13 | #14 (permalink) |
Junior Member Join Date: May 2008
Member: 780623 Status: Offline Thanks Meter: 0 | Certicate error sorry to be a bother but new to all of this. does this only apply to software by Binpda or all certs. If so do you know of a site listing Binpda software. Many thanks |
06-30-2008, 10:41 | #15 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | that is for all unsigned appz release by any group. |
The Following User Says Thank You to wsw243 For This Useful Post: |
Thread Tools | |
Display Modes | |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
Any one can hack Symbian Mobiles guide step by step | \/\/imran | Nokia Multimedia | 11 | 04-09-2012 23:14 |
To unlock latest version of spv c600 step by step guide tested 100% 10 times | malikzahidawan | HTC & Smartphones ( WM Without Touch) | 15 | 11-10-2010 10:59 |
signing symbian apps? | ronny7787 | Nokia Multimedia | 2 | 01-19-2008 23:47 |
