Old 03-25-2008, 02:34   #1 (permalink)
Member: 720891
Thanks Meter: 8
Nokia 5310 Xm (rm-303) Firmware Update New Version 05.81
NOKIA 5310 (RM-303) FIRMWARE UPDATE
NEW VERSION 05.81
NOTE: Only RM-303 products. NO RM-304 compatibility . To find out which code is your cellphone dial*#0000#.
The most radical change you'll get is a SIGNIFICATIVE increase of ringing or loudspeakers volume, I can really assure you there's a HUGE difference !!!
Follow general steps and ONLY those identified with your cellphone COLOR
Programs required:
-Nemesis Service Suite Beta 1.0.38.12 (NSS)
-Nokia Software Updater (NSU)
Files required:
-http://rapidshare.com/files/98122535...files.rar.html (Nokia 5310 red color)
-http://rapidshare.com/files/10031742...files.rar.html (Nokia 5310 blue color)
PRIOR NOTE : Remember always have your phone FULLY CHARGED and SIM instaled. Otherwise you can get a nice paperweight!!!. Confirm you have good internet speed and disable your screensaver or program it for 1 hour delay.
1)-Connect your phone to PC using USB cable (choose PC Suite mode on your phone) and if needed wait for driver installation. The cellphone should always be powered-on and Normal profile activated.
2)-Backup all your info from your phone, via PC Suite or using Backup option to your phone's microSD.
3)-Close any Nokia software or other that uses your phone.
4)-Open NSS, click on magnifying glass icon (right upper corner).
5)-Click on Nokia 6600 icon (Phone Info)
6)-In the block "Actions" click "Scan" button (the cellphone info should be displayed on the left text zone)
7)-In the block "Production Data Edit" click "Read" button. (Some cells will fill with info). NOTE: It's recomended to save/write and later restore this numbers once actualization is done in order to leave the phone with its original codes.
8)-In the "Product Code" option checkmark "Enable" box. Erase the numbers showed (generally they are like 05*****), write the new code which is gonna be:
0546968 (Nokia 5310 red color)
0548679 (Nokia 5310 blue color)
Click on "Write" button and wait until the word "Done" is displayed on the message state box in left lower corner.
9)-Close NSS.
10)-Open folder: C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\http://www.dsut.online.nokia.com.oti...roducts\rm-303
IMPORTANT: Application Data folder is a hidden system folder so you'll have to activate the "show hidden folders" option of your OS in order to access it. I recomend using Start>Run option and copy/paste the address shown to access directly to the folder.
Windows Vista users: the folder addres is: C:\ProgramData\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\http://www.dsut.online.nokia.com.oti...roducts\rm-303
In case you find any file you must erase ALL. This folder should be completely empty!! Do not close the folder window 'cause you will use it again..
11)-Open NSU. Click om "Start", then "Next". The software will give you two possible messages: (1) that you already have installed the latest version but if you wish you can REINSTALL it, or (2) that there's a new firmware available for your phone so you can INSTALL it.
12)-Either message shown you'll have to click "ReintalL" or "Install" button.
13)-NSU will start downloading update files (which sizes aprox. 33 MB), that's why it's recomended a good internet speed connection.
HIGHLY IMPORTANT STEPS:
14)-When update progress shows aprox. 26 MB downloaded you must "disconnect USB cable from PC" and let download process to normally ends. Then you'll get a message showing that phone connection is lost or the device is not recognized and will ask for connection RETRY. DO NOT PAY ATTENTION TO THIS, I mean, DO NOT CLICK on ANY button and do not close the software!!!.
15)- Go to folder: C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\http://www.dsut.online.nokia.com.oti...roducts\rm-303 and erase the following files:
(Nokia 5310 red color):
rm303__03.63.image_c_red
rm303__03.63.mcusw
rm303__03.63.ppm_c
(Nokia 5310 blue color):
rm303__03.63.image_c_blue
rm303__03.63.mcusw
rm303__03.63.ppm_c
16)-In the compressed file you'd preaviously downloaded,
N5310_flash_files.rar (Nokia 5310 red color)
N5310_blue_flash_files.rar (Nokia 5310 blue color)
you'll find three replacement files for those you've just erased, copy/paste them to the mentioned folder.
17)-Once you have replaced the files reconect the USB cable to PC and click "Retry" button on NSU window.
18)-The software will begin updating. Let this process to end normaly without touching ANY on the PC or cellphone. This process takes about 15 min. NSU will tell you that version 03.63 installation is correctly completed. What NSU doesn't know is that we replaced the files so don't worry for this message.
19)-The phone will restart and will ask for your SIM code. Maybe it will take a little longer loading but once you get to main screen dial *#0000# and confirm that your new firmware is V 05.81
CONGRATULATIONS!!!
Any questions are welcome!! Regards!!
The Following 5 Users Say Thank You to flamekeeper For This Useful Post:
Old 03-25-2008, 02:51   #2 (permalink)
Member: 720891
Thanks Meter: 8
IMPORTANT!!!
Folder adress is:
-Windows 2000, XP Users: C:\Documents and Settings\All Users\Application Data\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\www.dsut.onl ine.nokia.com.oti.caresuite\Products\rm-303
-Windows Vista Users: C:\ProgramData\Nokia\Nokia Service Layer\A\nsl_service_module_00001\vpls\www.dsut.onl ine.nokia.com.oti.caresuite\Products\rm-303
Unfortunately this forum auto-recognizes all the words starting with "www" as a URL link and I was unable to re-edit my previous post!
Old 03-28-2008, 02:43   #3 (permalink)
Member: 734819
Sonork: divon
Thanks Meter: 1
I am a complete newbie. Would that unlock the handset as well?
Thanks.
The Following User Says Thank You to divon For This Useful Post:
Old 03-31-2008, 10:39   #4 (permalink)
Member: 220144
Thanks Meter: 1
Thank you sir. I've been waiting for this upgrade. What is this 0548679 code for? Mine is 0548826. As much as possible, I dont want to change my product code. Can i upgrade without changing product code? Please help.
Thank you.
Old 03-31-2008, 10:42   #5 (permalink)
gobindopura's Avatar
Member: 487537
Thanks Meter: 61
Thanks
Old 03-31-2008, 10:44   #6 (permalink)
Member: 685445
Thanks Meter: 10
Nice update mate.....more power...
Old 03-31-2008, 10:58   #7 (permalink)
..::: Naveed :::..'s Avatar
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
Thnx for sharing nice work
Old 03-31-2008, 10:59   #8 (permalink)
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
Thanks
No brother it cant unlock u must buy codes from provider
Old 03-31-2008, 11:05   #9 (permalink)
Member: 172261
Thanks Meter: 368
just download 5310 RM-303_DP20_3.00__sw-05.81
then flash with phoenix
Old 03-31-2008, 16:53   #10 (permalink)
Member: 720891
Thanks Meter: 8
Thank you.
That code is for Euro GSM Zone. Your code is for Asia&Pacific-Philippine GSM Zone...is that right?
There's no problem changing the Product Code because you can latter change it back again to original number following the initial steps with Nemesis Service Software.
What I recommend you my friend is to use Product Code 0558555 and run normally NSU, because for that code firmware 05.91 was officially released and the language pack is the same your phone has right now (English, Chinese, Japanese, Philippine, Vietnamese. With this code you won't have to do anything else but to let NSU normally upgrade your phone. Latter you can change back your original Product Code.
Old 03-31-2008, 16:54   #11 (permalink)
Member: 720891
Thanks Meter: 8
This firmware is for Phoenix 2007.44 and there's no crack for that version. It's easier via NSU trick
Old 03-31-2008, 22:47   #12 (permalink)
Member: 739156
after update.. is it possible to set the product-code back to its original value?
Old 04-01-2008, 01:34   #13 (permalink)
Member: 220144
Thanks Meter: 1
Yes, it's for Philippines. Just flashed my 5310 per your instruction in the first post. ringing tones and music playback is loud. Still discovering for more changes.
Thank you flamekeeper...
Old 04-01-2008, 01:37   #14 (permalink)
Member: 220144
Thanks Meter: 1
flamekeeper's method is much much easier than Phoenix method.
Old 04-01-2008, 01:45   #15 (permalink)
humayun's Avatar
Member: 173592
Thanks Meter: 30
than************ q sir great work
N5310XM RM-303 SW 3.40 v.5.81 bastard3son Nokia Base Band 5 ( BB-5 ) 5 01-26-2011 05:33
Nokia 5800 XM RM-356 firmware 30 and 31.0.101 - service manual pitone02 Nokia Base Band 5 ( BB-5 ) 1 11-06-2009 23:03
Can I flash nokia 5310 XM to 5220 XM? amras555 Nokia Base Band 5 ( BB-5 ) 0 06-20-2009 18:46
5310 openline RM 303 ainne Nokia Base Band 5 ( BB-5 ) 0 09-26-2008 16:39
Page generated in 0.26597 seconds with 10 queries
