01-12-2008, 13:23 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 51
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | M300 bad imei after flash / NSpro1.3.7 Any Solution for that problem....write imei don`t work |
01-12-2008, 14:40 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | wow!!! you are faaaar behind from nspro... last NsPro version ns NsPro 3.7.3 Check on www.nsteam.org |
02-26-2008, 19:56 | #6 (permalink) |
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | Still no solution for M300 with 000000000 imei??? And of course i use the last / newest version of NS Pro Still need solution (Bad NVN-Zone) Last edited by *phone-company*; 02-26-2008 at 20:06. |
02-27-2008, 12:29 | #8 (permalink) |
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | for information...imei change in M300 is realy no problem if NVM zone is good. but if bad NVM zone (for example if you flash in repairmode/this will destroy NVM) then repair is not possible. Pls we need a fix urgent |
02-27-2008, 14:21 | #9 (permalink) | |
Product Supporter Join Date: Aug 2007
Member: 561932 Status: Offline Thanks Meter: 168 | Quote:
1. create patch or patched software (program -> otp.exe) (enter S/N with stickers). 2. download software and patch or download patched software. 3. if old Agere - download any good eep this models. 4. Power phone if old Agere - click button - old, if new click button - new(program -> default.exe). 5. if in log all Done - OTP is repair. no repair SWAP PCB - unknown S/N. | |
The Following 9 Users Say Thank You to alex999_ For This Useful Post: |
02-27-2008, 19:19 | #11 (permalink) | |
1. USE patch (software in phone and software do patch alike). strictly keep sequence an action download patch download EEP(needs any normal EEP -ANY with m300 with normal CalData) power on phone in soft(default.exe) - click button "OLD"(in log - UseDefCalDataone and StoreCaldataone) phone connected to cable. OTP restore ! - and repair imei to BOX, but before this, download any software(no repair mode !!!!) -otherwise imei repair only in RAM better use optiflash. | |
02-27-2008, 19:36 | #12 (permalink) |
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | what do you mean with download patch and download eeprom ???? You mean flash to phone or what????don`t found any working eeprom untill now what is msl code for m300 ??? on my sticker is following code: RVLP916173V is this serial number from sticker??? |
02-27-2008, 21:26 | #14 (permalink) |
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | ok, but can`t flash ist with nsPro...How could i flash these files..in optiflash message bad adress comes |
02-27-2008, 21:39 | #15 (permalink) |
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | ok, both files flashed...eeprom and patched file. Then imeichange ...in Programm it works but in phone still 0000000000 and no network |
f210 bad imei after flash | Denny_boy | UST Pro II | 1 | 06-11-2008 15:47 |
M300 is dead after flash | aukonline | Infinity-Box | 10 | 03-22-2006 11:37 |
bad imei after changing uem 6510 | yoya | Nokia Hardware & Hardware Repair | 7 | 12-18-2004 16:39 |
GD55 with bad IMEI affter flashing with the Rusian Soft | wiky | Panasonic | 7 | 06-11-2004 06:58 |
3330 bad imei after upgrade | pegonlo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-11-2004 16:53 |
