09-25-2007, 02:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | tmobile t729 (code solution and nspro dont work either): ust pro 5.6 reports read codes: reading data from box... power on phone... phone detected! loading preloader... preloader ok! loading 2nd loader... 2nd boot ok! getting flash id... manuf.: samsung chip type: kap29sn00m bypassing msl sec... msl sec bypass failed! possible damaged eeprom data, try again or write new eeprom. elapsed time (00:57) msl security bypass failed! when direct unlock phone get in blue tat mode but fail unlock too. |
09-25-2007, 13:36 | #5 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I tried with nspro, but let me try again, I have two T729 tmobile usa, maybe its new version. according to your schematic the pinout of e210 and d800 is the same, e210 connector only has a little more plastic on each side which has to be fixed. my modified connector works since I get blue tat mode and even boot up with ustpro. I am not new to modifying connectors, I do that for many years, when cables are not easy available yet. Last edited by mrfixit; 09-25-2007 at 13:44. |
09-25-2007, 17:06 | #6 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I realize e210 (t729) is not d800 cable, usb lines are reversed, so either buy original e210 cable or make ur own. I will make mine and post result, thanks to elco. |
09-26-2007, 13:39 | #10 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | T729 Direct Unlock works without problem ! After direct unlock phone will stay locked, YOU MUST ENTER #7465626*638*00000000# to finish unlock procedure. |
10-06-2007, 16:04 | #13 (permalink) |
Temporary banned !! Join Date: Jul 2007 Location: Toketek Age: 44
Member: 546766 Status: Offline Thanks Meter: 51 | no need to another cable it just d00 cable but it will do some modify.remove metal each 2 parts then put your cable be carefully.and push the direct unlock .after unlock use this code *2767*3855#.i am tested by ust-pro2. THATS IT THANKSSSSSSSSSSS |
unlocking a samsung t729 blast | leslie333 | Phone Unlocking Codes & Maps | 15 | 05-26-2014 14:15 |
samsung t729 unlock problem | lacasapc | NSPRO | 3 | 06-28-2008 15:23 |
Samsung t729 Blast T-mobile | bulletz | Phone Unlocking Codes & Maps | 3 | 02-27-2008 08:53 |
samsung t729 | aulakhraja | QUALCOMM Models (3G) | 0 | 02-21-2008 06:15 |
