Old 09-06-2007, 08:02   #1 (permalink)
hagard's Avatar
Member: 161547
Thanks Meter: 241
V170 Conversion 850Mhz/1900Mhz to 900Mhz/1800Mhz
Gadgets needed Infinity box
There are 3 kinds of HW of V170.the Xingular,Tracfone OLD HW and Tracfone New HW
Dissassemble the Unit:
So Lets Do The Hardware Modification First:
Original State of Band (850Mhz / 1900Mhz)
Band Change State (900Mhz / 1800Mhz)
Original State of SAW Filters
Changing 2 SAW Filters to Capacitors came from 8210,3210,3530 and add to resistor if
needed..for me i add 2 additional resistor and 1 capacitor in the vacant filter (Middle)
NOTE:
if your HW is OLD one no need to cut the TP or Remove the N1 Ball fron the CPU...Just unlock
it or if you want to debrand it Flash it,In case Your HW is New or Tracfone Here is the TP:
[IMG]http://i239.photobucket.com/albums/ff101/emanalansan63/Moto_V17x_repair_test_point.jpg
[/IMG]
This TP Is for OLD Tracfone (Cut Track)..This TP is came from Infinity Support,Try this
first Before you Remove the N1 Ball..
HOW:
1: Removing The CPU,and after removing Remove N1 ball and Mount it Back to the Board.after
mounting,You can Flash and Unlock the Unit.and after flashing you must remove again the CPU
and Mount it back together with the N1 ball.
2: Use Number 0 string of a guitar and Hook it to the N1 Ball,and Reheat the portion of the
CPU,near the N1 ball and Pull it out gently,and if you remove the N1 ball,Now you can Flash
and Unlock the UNit and After its Done,Put a llittle Ball of lead in Between the N1 ball and
reheat Gently the CPU untill it molds itself...Very Risky but thats the only Way...
Then flash the unit..
1: Open your Infinity Shell and Click Motorola,Click V170 Model...Check which com ports will
You use:USB to Serial or Com1.( Note Sometimes you will encounter errors on your USB to
Serial because of your Latency Time..the default is 16 change the Value to 8)
Check Repair Mode,Check Soft Restore and Check try to Power-on After Flash.Use X60 cales
came from your infinity Box..or T191 Cables.
2: Click the Flash Tab,and Flash it with V172 Firmware..(tested no errors)Check main select
main Firmware,Laguage and Flex..with Smart Write and Safe Mode..
Here are the Firmware,Unrar it:
http://rapidshare.com/files/53481925/V170.rar.html
http://www.megaupload.com/?d=SSS55PWF
3: After Successfully Flashing the unit it will Power Up itself,it means its working
already,But after powering it off it will not power again,Thats Normal.
4: Click Service Tab, SP-Unlock.After Unlock User/Phone/Lockcode must be reset in case.after
all is done.The unit is Not powering On.because the TP (Cut Track)or the N1 ball is still
not bring back to its original State.Which is Connect Cut Track and remount N1 Ball..
5: Reminder:
Never connect the CUT Track or Mount the N1 balls Until,Flashing,Unlocking,reseting is done
Because,it will not connect again...
This convertion courtesy of my friend emanalansan
http://gsmsandwich.com.ph/forum/showthread.php?t=37109
br
hagard
The Following 2 Users Say Thank You to hagard For This Useful Post:
Old 10-01-2007, 16:00   #2 (permalink)
sunsco's Avatar
Member: 216438
Sonork: 160962
Thanks Meter: 31
mr hagard how can we convert c115 single band to dual band
Old 10-01-2007, 16:07   #3 (permalink)
sunsco's Avatar
Member: 216438
Sonork: 160962
Thanks Meter: 31
Old 03-07-2008, 09:13   #4 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
i try to flash firmware V172 in support, but my LCD has problem(wihte) but i can make call !
If i try to flash firmware v170, phone ok but i cant make call.
This is firmware that i can make call but has problem with LCD
Current model: V170,V171,V172,V173
Loading file v.02...
v172_5.7.19_Main.20M_2.bin loaded
V172_5.7.19_LPLA_Es_Pt.20P.bin loaded
V172_5.7.19_Flex_90_61_2T03.20F.bin loaded
Old 03-07-2008, 09:34   #5 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
problem solved !
tanks
Old 04-29-2008, 14:50   #6 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
v170 band change
Originally Posted by ticoichip View Post
problem solved !
tanks
can u post details how u have done pls ???
Old 04-29-2008, 15:00   #7 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
can i convert C168?...................
The Following 2 Users Say Thank You to shahzaadbutt For This Useful Post:
Old 04-29-2008, 15:58   #8 (permalink)
Member: 282641
Thanks Meter: 22
Use MSS Box if u have one it will correct lcd errors, just flash with its latest firmware...
Old 12-08-2008, 10:17   #9 (permalink)
Member: 136052
Thanks Meter: 75
Сan i convert C168 to 900/1800 ???
Old 12-08-2008, 12:30   #10 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Probably yes. You need to find C168 service manual with schematic and check it to see what is HW difference.
V170 Conversion 850Mhz/1900Mhz to 900Mhz/1800Mhz sexywise Multi-box LITE 17 03-22-2008 17:21
V170 Conversion 850Mhz/1900Mhz to 900Mhz/1800Mhz sexywise Multi-Box 1 03-21-2008 09:52
How to Convert 2610b to 2610 , 850/1900Mhz to 900/1800Mhz imran_qasim Nokia Hardware & Hardware Repair 4 04-19-2007 08:24
C332 - 1900mhz to 900/1800mhz possible? livewirecebu Motorola P2k 2 11-07-2003 17:20
Page generated in 0.22644 seconds with 9 queries
