09-18-2006, 22:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | k750i CID49 RED dead repair PROCEDURE. 1) Attach the phone but select k750I in the little window. 2) Unlock RSA 3) Attach the phone and Direct Unlock at the end detach phone remove battery and cable and plug in again. 4) Attach the phone and flash FS with this K750_R1BC002_FS_EU3_CID49.fbn 5) Customize file system 6) Attach the phone and flash SW with K750_R1BC002_MAIN_EU_EMEA_CID49.mbn 7)Turn off the phone and remove battery and put in again. 8) power on and voilą phone is alive. Tanks who test and develop the procedure. |
The Following User Says Thank You to Pandemonio100 For This Useful Post: |
09-19-2006, 08:53 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @PANDEMONIO AS U TOLD UNLOCK RSA BUT AFTER MAKING UNLOCK IF PHONE LOG SAYS RSA protection state cannot be determined for this CID. AND NO OTHER OPTION WE CAN USE EXCEPT [UNLOCK RSA] IF WE MAKE NE OTHER OPTION LIKE DIRECT UNLOCK ,FLASH MAIN ETC THE PHONE UPPER RED LED BLINKS FOR 8 TO 9 TIMES AND NOTHING ELSE TRIED SEVERAL TIMES |
09-19-2006, 09:00 | #3 (permalink) |
Member: 3381 Status: Offline Thanks Meter: 1,171 | I have had same problem RSA cannot be determinate for this CID, but i continue the same procedure and my 3 phone alive have you tested? Have you select K750i and No Autodetect? |
09-19-2006, 09:03 | #4 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | When Cruiser Log Says Waiting For Acknowledge Phone Blinks Red Led Upper Side For 8 To 9 Times And Then Invalid Responce |
09-19-2006, 10:12 | #6 (permalink) |
Freak Poster Join Date: Dec 2004 Location: UNITED KINGDOM
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | 1: Attach the phone 2: Unlock RSA 3: Attach the phone and Direct Unlock 4: Attach the phone again and flash FS with this K750_R1BC002_FS_EU3_CID49.fbn 5: Customize file system 6: Attach the phone and flash SW with K750_R1BC002_MAIN_EU_EMEA_CID49.mbn 7: Turn off the phone and Enjoy 100% tested |
09-19-2006, 11:22 | #7 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 39
Member: 106320 Status: Offline Thanks Meter: 1 | Hi Pandemonio100....Funny that i saw you posted the solution is just the same with mine ,even the download link is the same..... Here is my solution : https://forum.gsmhosting.com/vbb/f569/way-solve-k750i-block-1-when-flashing-fs-330634/ And here: /vbb/showthread...=301067&page=5 WBR |
09-19-2006, 12:48 | #10 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | k750 and z530 also disconnect between 1% to 30% K750_R1BC002_FS_EU3_CID49.fbn K750_R1BC002_MAIN_EU_EMEA_CID49.mbn this files are usb smart files if you flash with usb smart your phone will work perpectely |
09-19-2006, 13:04 | #11 (permalink) | |
Member: 106320 Status: Offline Thanks Meter: 1 | Quote:
You right!! I got both USB and Cruiser but i think Cruiser is the best that why i use Cruiser to save my phone not USB | |
09-19-2006, 14:03 | #12 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Here
Member: 5858 Status: Offline Thanks Meter: 1 | thx for those files, I could not sort this D750 out with the cruiser files for CID 49. But I have same problem trying to flash W550 CID49 red with cruiser flashes, can any one post the fbn and mbn for the w550 please? |
How to Unlock K750i CID49 RED check here | pakstar | SETool2 | 16 | 09-23-2016 11:04 |
K510i CID49 RED dead repair PROCEDURE. | Miftahudin | Cruiser Suite | 10 | 05-30-2008 16:20 |
how to solve K750i CID49 Red Dead. | ales6orah | MT-BOX | 1 | 12-25-2006 12:27 |
K750i cid49 red please help!! | honex | Cruiser Suite | 2 | 05-04-2006 01:17 |
K750i CID49 Red ??? | blackrose | Cruiser Suite | 3 | 04-15-2006 10:34 |
