Federal One Federal One & Prodigy Support Section |
08-15-2006, 10:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | NSS as BB5 Simlock Logger READING BB5 ASK FILE Changing to Local Mode: To read ASK file, your phone has to be in Local Mode. Please follow this procedure after starting the sotware. 1. Power up the phone with its own battery. 2. Connect DKU-2/CA-53 cable. 3. Plug to the USB port and install all drivers. 4. Press Scan in the Phone Info page to connect to the phone. 5. Select the Local option box and press 'Change' 6. Wait for the phone to re-boot and show 'Local' on its screen. 7 . Unplug and plug again the USB cable, wait the beep from Windows 8. Press Scan again. Repeat step 7 if you can't read the phone info 9. You are ready to upload Checking the Simlock Status: Press 'Read' in the Simlocks Page in the Security Menu to see the Sim Locks status. Reading Ask File: Press 'Read' in the Certificates Page to select a file name for your Ask file. Then press 'Save' and wait 1 second for the file to be created. UPLOADING BB5 RPL FILE Changing to Local Mode: To upload RPL file, your phone has to be in Local Mode. Please follow this procedure after starting the sotware. 1. Power up the phone with its own battery. 2. Connect DKU-2/CA-53 cable. 3. Plug to the USB port and install all drivers. 4. Press Scan in the Phone Info page to connect to the phone. 5. Select the Local option box and press 'Change' 6. Wait for the phone to re-boot and show 'Local' on its screen. 7 . Unplug and plug again the USB cable, wait the beep from Windows 8. Press Scan again. Repeat step 7 if you can't read the phone info 9. You are ready to upload Uploading the file: Please select the file by pressing the 'Write' button in the certificates page. Clicking on 'Open' will start the loading of the file to the phone. On success you should see 'Done' in the status bar. You can now press 'Read' in the Simlocks Page to see the updated Sim Lock status. FAQ B-phreaks Ltd, 2006Q: Do i need Prodigy, F1, Nemesis or Diamond to run NSS as a BB5 Simlock Logger ? A: No. NSS runs as a standalone BB5 logger. You only need to download the software, install it, plug the phone to the USB port with the supplied USB cable and connect to it. Q: Are the additional FBUS features limited in a Logger Mode ? A: No. You can read info, read simlock status, read startup selftests etc. The only feature that is limited is the BB5 USB flashing, that will require Diamond plugged in, and valid application loaded. Q: Can i upload the NPC(Nokia Public Certificate) into the phone using NSS in Logger mode and usb cable ? A: Not at the current moment. You can upload only the default simlock data into the phone. To upload NPC you will need Nemesis box or F1 device. The RPL log is the same though, so you can have it as a backup and upload at later date, when you purchase your F1 device. Q: Where could i download the NSS software from? A: You can download it from our web page. The minimum version needed that supports this feature is 'Nemesis Service Suite Beta 1.0.37.3' Q: How do i get logs calculated ? A: If you need one file only and can pay via Credit Card/PayPal account, you can use this link, otherwise and for trade enquiries please send a mail to: [email protected] Last edited by Bph&co; 10-17-2006 at 17:18. |
before i use NSS for bb5 simlock restore, some questions.... | .:GSM International:. | Federal One | 5 | 03-11-2011 09:28 |
After install NSS to bb5 logger | kikodog | Federal One | 0 | 03-04-2007 16:05 |
Does the NSS BB5 Simlock Logger solve 6280 phone restricted. | ales6orah | Federal One | 4 | 11-07-2006 04:11 |
Mr Bph&Co!!NSS as BB5 Simlock Logger question | Liu2 | Federal One | 2 | 11-06-2006 09:30 |
